2016 Ford F-150 Limited, ECM/Inputs/Outputs Waveform
The blue channel is the ckp and it has 58 toggles in one 360 deg crank rotation. PCM pin 11 yel/vio, PCM connector closest to the fender. The red channel is the bank 2 intake cmp, PCM pin 26 grn/vio and the VCT sol are unplugged, engine running at idle. The gr...
Vehicle Data2016 Ford F-150 Limited 3.5L
Engine | 3.5 L / 6 cyl / GAS |
Trans | 6-speed AutomaticTransmission (Electronic) |
Component | , |
Condition | Known Good |
