Rotor slip ring
Notice the heavy solid wire at the base of the slip ring. Don't cut that off with dikes. This will create a stress crack in the carrier that supports it where the rotor wire solders to that junction. Use a dremmel tool to very gently cut that heavy solid wire ...
Copyright ©1995-2024 iATN. All rights reserved.
