sense circuit
The sense circuit on B Chrysler alternator systems is an internal resistor from alternator output, through 2.4K ohm resistor, to sense pin on alternator. This is a voltage divider network. That 2.4K ohm resistor connects to an internal resistor in the PCM. Th...
Copyright ©1995-2024 iATN. All rights reserved.
