Voltage regulator wiring.
External voltage regulator wiring. Be sure to run a separate wire from metal VR case to battery negative. VR will blow if ground connection is bad. Use 500 ohm resistor (1 watt) connected to I terminal. A terminal constant battery plus, F terminal alternator f...
Copyright ©1995-2024 iATN. All rights reserved.
