2016 Jeep Cherokee Latitude, ECM/Inputs/Outputs Waveform
Posted to the Waveform Library on 11/1/2024
Green CKP,Purple and Yellow Cam 1&2,Red Injector voltage,Blue is Ign coil primary,Light blue PCM power,Gray Ignition coil 12 volts feed. The Tipm isnt supplying voltage under a load to fire the coils. Cranks no start starts and stalls.
2016 Jeep Cherokee Latitude 2.4L
Engine2.4 L / 4 cyl / GAS
Trans9-speed AutomaticTransaxle (Electronic)
