1998 Dodge Caravan, CKP Sensor, CMP Sensor, Ignition - Primary Waveform
Posted to the Waveform Library on 1/11/2006
Crank-Cam relationship with coil primary current. The relationship is incorrect for this engine. (timing belt or flywheel problem, I will update this when I know for sure)
1998 Dodge Caravan SE 3.0L
Engine3.0 L / 6 cyl / GAS
Trans3-speed AutomaticTransaxle
SubsystemIgnition
Component, ,
SubsystemIgnition
Component, ,
