1997 Chevrolet Cavalier, VSS Schematic
Speedometer circuit showing VSS inputs to PCM (AC signal) & VSS output from PCM on PIN #16 (Digital signal @ 4000 pulses per mile). Does the PCM actually produce an output voltage on PIN #16 @ 4K pulses/mile or is it grounding this circuit at that rate (with s...
Vehicle Data1997 Chevrolet Cavalier LS 2.2L
VIN | 1G1JF5241V |
Engine | 2.2 L / 4 cyl / GAS |
Component |
