SKF U-Joint Finder Ruler
Posted to the Waveform Library on 4/22/2016
When all you have from a vehicle is a yoke or a u-joint use the SKF yoke / u-joint ruler to determine the correct driveshaft series you are working with. Once you determine the correct series refer to the current SKF U-Joint catalog to find the correct U-Joint part number for the application.
Erica from Illinois
